John fsprogrammer
Device Initializtion Window.   I am trying to take advantage of Device Initialization in version 6.3
Discussion created by John fsprogrammer on Apr 6, 2010
Latest reply on Apr 28, 2010 by John fsprogrammer
When I use the Pull down box to try to change from PTE to PTD etc, the ports seem to get all screwed up.  IE the port setting are now the same as the Port i just switched from.  Example - use the pull down menu in attachement to switch from PTA to PTB
