Carl Norman
String alignment issue
Discussion created by Carl Norman on Mar 25, 2010
Latest reply on Mar 26, 2010 by CompilerGuru
(CW7.1.2 patch build 11)
How do I get my string alignment to stop adding extra bytes in the following example?
Example:
nvm.c
volatile uchar ID1[12] = "123456789";
volatile uchar ID2[12] = "987654321";
linker:
 .NVM_Page:
  nvm.c (.data)
  nvm.c (.rodata)
  nvm.c (.text)
 } > my_NVM
map file:
10060026 0000000C .data   ID1(nvm.c)
10060034 0000000C .data   ID2(nvm.c)
The map file shows ID2 at 0x10060034 instead of 0x10060032. If I change ID1 array to ID1[14], ID2 array is still at 10060034. Single byte varibles, 2 byte varibles are fine, its just arrays as far as i can tell.
What do I need to do to fix this issue?
