I'm trying to compile a part of a program that should work normally but I don't understand why this error appear.
It should be a very simple problem but I can't resolve it.
Here's the following code :
#ifndef _MC9S08DZ60_H #define _MC9S08DZ60_H typedef unsigned char byte; >>>>> C2450: Expected: ; = , #endif
Thank you for the help if someone has an idea
Hello
Here I would suggest you to generate the preprocessor listing for of the C source file where you get the message and check how the macro are expanded.
Byte might be defined differently some other place.
CrasyCat
