AdamEV
CW10, M52233DEMO and "Target request failed: Could not open memory configuration file."
Discussion created by AdamEV on Mar 11, 2010
Latest reply on Mar 25, 2010 by CrasyCat
Hello!
Project created with Processor Expert at Code Warrior version 10. All board settings ok. Simple test program - LED blinking on two beans.
I choose Internal flash option (others also doesn't work), generate, build, no errors, RUN and...:
"Target request failed: Could not open memory configuration file.".
I tried to assing files (.mem and .cfg) or copy to source folder - no change. No more ideas...
Standard question: What should I do or what am I doing wrong?
Thanks in advance
Adam
