I have a fpga image file with .fls extension. Does somebody know the file format for such file extension. It's binary file with header and data parts. For example, the .bin file is 32 bytes header and the rest is the data.
Momo
Solved! Go to Solution.
Do a Google search on .fls extension or .fls file. There are several different format types; you will have to determine which format description fits the file that you have.
---Tom
---Tom
Hi Tom,
I did a Google search on .fls extension and .fls file. I am actually trying to check which format matches best.
Momo
