I have MQX 3.5 + USB host with another task. For my application I need to utilize an interrupt with level and sublevel of 7 because I have real time requirements.
I can explain better ... my interrupt can't be interrupted for other interrupts!!!
I reduce RTC_INT_LEVEL from 7 to 6 and insert a my interrupt with level 7 so I soddisfy my real time requirements.
Can I do this?
Which role has RTC interrupt in MQX?
With this change do I cause problems of task switching or others problems?
Thanks for the support.
