Is there any way to halt the debugger, and dump all of the variable data contained in the Data:1 window to some sort of .TXT file, or CSV, etc.?
I can't seem to find any way to do it, and using alt-prntscrn to paste a pic of the data window into Powerpoint is tedious, to say the least.
Also, is there any way to expand the content of ALL structures in the Data:1 window, instead of having to manually click the for each one? I have some large arrays for data logging, and it really slows down the debugging process to expand each structure one-by-one.
Thanks in advance for the help.
Solved! Go to Solution.
Hello
You can dump content of Data:1 window using the Command
Data:1 < DUMP
If you want to store the Data window dump to a file use the commands:
LF DataDump.txt
Data:1 < DUMP
NOLF
Please Refer to Debugger_HC12.pdf BOOK IV for more information on the available commands.
I am not aware of a simple way to expand all structure variable in the Data window.
CrasyCat
Hello
Data:1 < DUMP
LF DataDump.txt
Data:1 < DUMP
NOLF
CrasyCat
