Download *.s19 file to MC9S12XEQ512 using CodeWarrior 5.0, Hiwave.exe and P&E USB Multilink
Question asked by Razvan Marc on Feb 23, 2010
Latest reply on Apr 15, 2015 by Fiona Kuang
Hello!
I am using CW 5.0, hiwave.exe and P&E USB Multilink Interface.
When I`m flashing a *.elf file down to the microcontroller everything works fine.
The problem appears when trying to download a *.s19 file to the microcontroller.
The following error is issued by the software:
"Error while writing to 7EC000..7EC200.
Information: No memory at this address."
I think the problem is the way that the hiwave treats the flash memory regarding elf and s19 files.
The configuration seems to have banked addressing witch fits for elf files, but doesn't work for s19 file witch uses linear(or physical addressing).
What settings do I have to make in order to be able to flash the s19 file?
What do I have to change in order to have linear addressing when flashing s19 file?
Maybe i need to create a new *.fpp file?
Thanks!
