EQADC Result FIFO overflow is disturbing storage of results at the right software locations
Question asked by Raghu das on Feb 8, 2010
Latest reply on Jul 29, 2011 by Raghu das
I am converting 32 commands of analog input through EQADC of MPC5566 controller. I am using 5th command FIFO and using EDMA channel 11 to transfer commands from user software command buffer to CFIFO 5 and configured sampling time as 8 ADC clock cycles. The clock used here is 144Mhz.
 EDMA channel 12 is used to tranfer result from RFIFO 5 to software managed result queue.
I have observed that there is a mismatch in the storage of results at the correct location of software queue that has been set by user and this is occurring when result fifo overflow flag is set. I configured result overflow fifo overflow interrupt and adjusted or realigned the result queue. But I want to know what is the root cause for this. Can anybody help me to find the root cause for buffer mismatch?
Thanks in Advance,
Raghu.
