Global Addressing problem in MC9S12XF512
Raneesh
I am facing problem in assigning adress to a pointer. I am using banked memory. The variable definition and assignment as follows.
volatile uint16 * __far header;
header = ((volatile uint16 * __far)(0xff000));
In the debugger window I am getting the address in header as 0xf000 instead of 0xff000. Please provide help in solving this problem.
Raneesh
CrasyCat
Specialist III
Hello
Which version of CodeWarrior for HC12 are you using?
I tried with V4.7 and I get header set to 0xFF000
To retrieve the version number:
- Start CodeWarrior
- Select Help -> About Freescale CodeWarrior
- Click on "Install Products"
- CodeWarrior version used is displayed on top in the Installed Products dialog.
CrasyCat
CrasyCat
Specialist III
Hello
- Start CodeWarrior
CrasyCat
