hi all, i am trying to add arora browser to my package list and compile it as a individual application. when i tried ltib -m prep arora
--> Cannot find spec file that contains the package name arora.
If necessary please give the whole spec file name (with the .spec extension).
here is my spec file(arora.spec).
%define pfx /opt/freescale/rootfs/%{_target_cpu}
Summary : Arora web browser
Version : 0.10.2
Release : 1
License : GPL
Vendor : Freescale
Packager : xmanxxx
Group : /usr/share/doc/rpm-/arora
URL : http://xxxx
Source : arora-0.10.2.tar.gz
BuildRoot : %{_tmppath}/%{name}
Prefix : %{pfx}
.... rest is same as template spec.
can anybody tell me wht is missing
thanks
manz
I have the spec file in:
ltib/dist/lfs-5.1/arora/arora.spec
I have the package file with the other packages.
And I add the package in those files:
ltib/config/userspace/sysconfig.lkc
ltib/config/userspace/packages.lkc
ltib/dist/lfs-5.1/common/pkg_map
ltib/dist/lfs-5.1/sysconfig/sysconfig.spec
Medina
Try as follows:
./ltib -p arora.spec -m prep
Fabio Estevam
I have met the same problem.
If you use
it could work.
But I want to know why "./ltib -p arora -m prep" can not work.
