Would someone be kind enough to share their RTC to Actual Time/Date conversion? Here is some code that works on my PC to convert to date and tim, but the data types are different in MQX along with something else:
/* a sample program that return local time. */#include <stdio.h>#include <time.h>int main() { struct tm *ptr; time_t lt; lt = time(NULL); //return system time printf("time(NULL) = %d\n", lt); ptr = localtime(<); // return time in the form of tm structure printf(asctime(ptr));}
OUTPUT:
time(NULL) = 941830207 Fri Nov 5 14:30:07 1999
Thanks.
Solved! Go to Solution.
I have used something like:
void setTimeFromDate(uint_32 year, uint_32 month, uint_32 day, uint_32 hour,
uint_32 minute, uint_32 second, uint_32 millisec){
TIME_STRUCT MQX_time;
DATE_STRUCT DateStruct;
RTC_TIME_STRUCT RTC_time;
DateStruct.YEAR = (uint_16)year;
DateStruct.MONTH = (uint_16)month;
DateStruct.DAY = (uint_16)day;
DateStruct.HOUR = (uint_16)hour;
DateStruct.MINUTE = (uint_16)minute;
DateStruct.SECOND = (uint_16)second;
DateStruct.MILLISEC = (uint_16)millisec;
_time_from_date(&DateStruct, &MQX_time);//Convierte la fecha a tiempo MQX
_rtc_time_from_mqx_time (&MQX_time, &RTC_time);
_rtc_set_time (&RTC_time);
void getDateFromTime() {
_rtc_get_time (&RTC_time);
_rtc_time_to_mqx_time ( &RTC_time, &MQX_time);
_time_to_date(&MQX_time, &DateStruct );
Does that suits your needs? I dont completely understand your problem.
I have done some research, and it seems the MSL library needs some modification to get everything working, which seems long and painful to setup as I have not done any of this before...
Is there a 'simple' way to do something like this:
_rtc_get_time (&time_rtc); //Get the time from the 52259 RTC
_Convert_RTC_to_TM(&time_rt, &TM_Struct); //Some custom converter function
chr_ptr = asctime(&TM_Struct); //Get the time string
I really just want to show the date / time for logging, I am not worried about daylight savings, time zones etc as we will use UTC.
Ahhhh, my mistake, I didnt realise that the date function was available from MQX as its not in their example, I assumed we needed to use time.h. Time.h requires the MSL library to be rebuilt and configured to work with your hardware etc... Obviously not required! I should have searched the RM a little better!
