Dear All,
I want to use UART on LINFlex0 of MPC5604B. Per reference manual, LINFlex needs to be configurated in Initialization mode. I set LINCR1 to 0x00000001, but LINS field in LINSR is not 0001 (Initialization mode).
Could you please tell me how to set LINFlex0 into Initialization mode? Thanks in advance for your kindly help!
Michael Tang
Solved! Go to Solution.
Hi, All,
The problem was caused by incorrect setting of peripheral set clock. The DE0 should be set because baud rate related to Fperiph_set_1_clk.
Best Regards
Michael
Hi, All,
Best Regards
Michael
HI,
Could you please post the code..
It would be very helpful for me.
Thank you
So glad you finally got to make the module to work. I am having a lot of problems to get this module to work, so ¿could you upload your code for the UART configuration? The problem is that I just can make it work and I had tried what you said worked on you.
Thanks in advance!
