Hussain Aftab
MC9S08QG8 KBI and SCI interrupt need help..
Discussion created by Hussain Aftab on Dec 22, 2009
Latest reply on Dec 22, 2009 by Tony Papadimitriou
Hi i am using MC9S08QG8, according its data sheet
the SCI interrupt has higher priority than KBI interrupt
but in my code when the processor is in the KBI ISR
it does not serve the SCI interrupt..
what am i missing or doing wrong.?
CODE:
// ********* PERIPHERAL INITIALIZATION ********* //
void PeriphInit(void)
  SOPT1 &= 0x0F;
  // ********** IO Port Initialization ********** //
  PTAD = 0x00;
  PTADD = 0xF7;
  PTBD = 0x00;
  PTBDD = 0xF2;
  ICSTRM = NVICSTRM;
  ICSC2 = 0x00;
  ICSC1 = 0x04;
  // ******** Serial Communication Interface ******** //
  SCIC1 = 0x00;
  SCIC2 = 0x2C;
  SCIC3 = 0x00;
  SCIBDH = 0x00;      // For 9600 Baud rate
  SCIBDL = 0x35;      // For 9600 Baud rate
  // **** Flash Registers Initialization **** //
  FSTAT = 0x30;       // Clear error flags
  FCDIV = 0x13;
  // **** Keyboard Interrupt Initialization **** //
  KBISC = 0x06;       // Select both edges and level detect
  KBIPE = 0x08;       // Enable KBIP3 (PTA3) as keyboard interrupt
  KBIES = 0x00;       // Select Low level Detect
// ******* SERIAL RECEIVE INTERRUPT ******* //
  void interrupt 15 RDRF_ISR(void)
   SCIS1 = 0x00;
  receivedbyte = SCID;
  tag_received[count] = receivedbyte;
  count++;
   if(count == 12)
    tag_recv = 1;
    PTAD_PTAD1 = 1;
    PTAD_PTAD0 = 1;
    //flash_write();
    for(k = 0; k < 2; k++)
      Delay_100us(255);
    PTAD_PTAD1 = 0;
    PTAD_PTAD0 = 0;
    count =0;
  //while(SCIS1_TDRE == 0);
  //SCID = receivedbyte;
// ******** KBI INTERRUPT (PUSH BUTTON) ******** //
  void interrupt 18 KBI_INT(void)
    //KBISC_KBIE = 0;
    Delay_100us(255);
    KBISC_KBACK = 1;
    for(q=0;q<3;q++)
      if(tag_recv == 1)
        flash_write();
        tag_recv = 0;
        break;
      PTAD_PTAD1 = 1;
        Delay_100us(255);
      PTAD_PTAD1 = 0;
        Delay_100us(255);
      PTAD_PTAD1 = 1;
        Delay_100us(255);
      PTAD_PTAD1 = 0;
      for(k = 0; k < 50; k++)
        Delay_100us(255);
    KBISC_KBIE = 1;
void main(void)
  unsigned int i,c = 0,flag = 0;
  tag_recv = 0;
  EnableInterrupts;
  PeriphInit();
  while(1) // Forever
     for(i=0;i<14;i++)
     if(i > 11)
        SCID = '\n';
        Delay_100us(10);
        SCID = '\r';
        Delay_100us(10);
     SCID = (*((byte *)tag_1 + i));
     Delay_100us(10);
  } // end of while(1)
} // end of main
