Shahar Ben-David
Function absolute address setting
Discussion created by Shahar Ben-David on Dec 17, 2009
Latest reply on Dec 18, 2009 by Shahar Ben-David
I am writing a HID bootloader. My first try will be a single project approach, this way the USB stack will be used only once.
Only USB interrupts are shared between the bootloader and application code.
In order to redirect all application interrupts to the Application code area I need to Fix all interrupt routines in an absolute flash address within the application code area.
I could not find the way to tell the linker to place a specific function in a specified flash location.
Your help is highly appreciated.
S.B.D
