I'm using usb tap to program 56f8006.
On circuit, on which usb tap was connected, short circuit occured on electronics side (motor control).
Bad news. I didnt't had any optical isolation between electronics and usb tab, therefore usb tap is damaged == is in short circuit on USB side.
Did anyone managed to repair usb tap (is there any possibility that I damaged just some supply circuit not uC or flash)?
There's quite a little army of chips and a big mcu under the hood
Dejan
