Eduardo Dias Vilela
How generate a s19 with longword address
Discussion created by Eduardo Dias Vilela on Dec 2, 2009
Latest reply on Dec 3, 2009 by Eduardo Dias Vilela
Hi coleagues,
Can somebody help me this tricK? I need to generate a s19 file with 32 bits of address. In .list file, I get: just put   LLEN 32 on the file thatthe address in this file appear in 32bits, but, in s19 file, is put just the address needed. For example: if my code (or data table) start at $0100, the s19 uses 2bytes. If starts as $100000, the s19 file uses 24bytes to specify the address. If I put my data at $01000000, then compiler just put 3bytes in s19 file.
My question is: how force it to use 4bytes in s19 file?
Thanks by any help!
