out of my memory there is a SRECORD command in the prm file for this purpose, check the linker manual.
Hello
In order to add content of a S record file to your final executable you can use the command HEXFILE in your linker parameter file (.prm).
Please refer to "Build_Tools_Utilities.pdf" chapter "Smart Linker" and search for HEXFILE for more information
CrasyCat
