Clarification on BKGD connection
Discussion created by Guest on Nov 19, 2009
Latest reply on Nov 19, 2009 by Guest
Hi guys,
I read on the forum some where that the Vdd pin on the BKGD connector of the USB-ML-12E is a read pin, so when connecting to a target circuit that uses external power supply the Vdd pin on the BKGD connector is connected to the external power supply also.
Is this correct???
