Processor expert does not create code for the Timer Interrupts - Timer compare, overflow, ....
Question asked by Mansukh Sheliya on Nov 5, 2009
Latest reply on Nov 5, 2009 by Processor Expert
I have added "Peripheral initialization Bean for the CPU 56F8346 - Quad Timer Module (TMR)"
And enabled Timer compare Interrupt with ISR name.
Processor expert(PE) updates Interrupt vector table with specified ISR name and gives prototype also.
It does not define the ISR function in the timer module.
PS gives message that the routine must be implemented in the user code, it is not generated by PE. Only external prototype it provides in the bean module header file.
In user code, where do you recommend to create the routine definition? Any reason of not providing support in PE to generate the routine definition/implementation?
- Mansukh
