Does anyone have an example of a Broadcasting (send/recv) on coldFire 5225X?
My guess is that to broadcast, you just send to (on UDP) to IP adress 255.255.255.255. Anything broadcast on the port you opened will recv.
hi,
Yes, I did it before, its working, the problem was: i received my UDP pack back, because i had a UDP sock opened, than, i just get off this pack from my fifo.
Thank You.
Eng. Clóvis
