I’m using CodeWarrior 7.1 on Mac OS X.
I’d like to use syntax coloring for numbers, like in Apple’s Xcode IDE.
I tried the « custom keywords » preference pane by adding all the numbers from 1 to 9 but that doesn’t work (the numbers still draw black).
Any suggestions or do I have to write my own COM plugin ?
Solved! Go to Solution.
Hello
Freescale CodeWarrior no longer supports desktop programming for Mac or Windows.
So you may not find an answer to your question here.
As far as I know CodeWarrior IDE does not support specific coloring for numbers anyway.
CrasyCat
Hello
CrasyCat
