Francois Bouchard
FEC buffer overrun. MCF5282 CW7.1.1a please help
Discussion created by Francois Bouchard on Oct 6, 2009
Latest reply on Nov 19, 2009 by Francois Bouchard
Hi all,
I'm stuck with an Ethernet driver problem.  I'm getting buffer overrun errors on some packets which subsequently are dropped.  I'm using lwIP1.3.0 TCP/IP stack, but my problem is on the low level (drivers).
I have included my driver code (which has been taken mostly from the FreeRTOS port), but again, please concentrate on the FEC buffer ring code, frame reception code, and its ISR routine.
 files:
fec.c     // the receive task, Rx ISR, init code, etc.
fec.h
nbuc.c   // the fec buffer ring module
nbuf.h
regards
FB
