Can somebody guide me, I was working on 9s12E128 but while compling it was including 9s12dp512 header file. I tried again, make sure that I did the right selection of 9S12E128. But result is same.
Now what is happening that it is not recoginising some of the Ports.
Did you the following option...?
1. Go, the "Project" tab on your codewarrior tool bar
2. Select "Remove Object Code" (a popup window appears)
3. Check the box "Compat targets"
4. And then, click "Current Target" tab in that pop up window
5. After this, finally .. recompile your project again..
If you didnt try it already, please check the above the steps..
And,I think you must have already checked the name of the header file in your project tree on the left side of the window.
