In the 908AC family, does writing 000 to the RTIS2-0 bits also clear the prescaler?
I want to start the RTI from zero each time I enable it. No mention of this in the data sheet.
Writing a value of zero to the RTIS bits actually disables the timer. I guess the write of a non-zero value, to re-enable the timer, is likely to clear the prescaler. Maybe writing any new value will do the same. This should be relatively easy to test.
Mac
