Please need a help with AN_1219 .
Question asked by Roberto Beghetto on Sep 15, 2009
Latest reply on Sep 17, 2009 by bigmac
I need to use a 32/16bit unsigned Divide in assembler with the mc9s08aw32 or MC9S08GB60 .
Unfortunately I am a Beginner .
I have copied and editated the unsigned divide in this mode :
; export symbols
            XDEF Entry, main
            ; we use export 'Entry' as symbol. This allows us to
            ; reference 'Entry' either in the linker .prm file
            ; or from C/C++ later on
            XREF __SEG_END_SSTACK   ; symbol defined by the linker for the end of the stack
; include derivative specific macros
            INCLUDE 'mc9s08aw32.inc'
; variable/data section
MY_ZEROPAGE: SECTION  SHORT         ; Insert here your data definition
INTACC1 RMB 4 ;32-bit integer accumulator #1
INTACC2 RMB 4 ;32-bit integer accumulator #2
SPVAL   RMB 2 ;storage for stack pointer value
; code section
MyCode:     SECTION
main:
Entry:
; Insert your code here
;*******Assegnazione Valori test.
          MOV      #$01,INTACC1
          MOV      #$F4,INTACC1+1
          MOV      #$F4,INTACC1+2
          MOV      #$01,INTACC2
          MOV      #$F4,INTACC2+1
START     LDHX    #$450 ;load H:X with upper RAM boundary + 1
          TXS     ;move stack pointer to upper RAM boundary
          CLRH     ;clear H:X
          JSR     UDVD32 ;call 32 x 16 multiply routine
          BRA *   ;end of main routine
;* 32 x 16 Unsigned Divide
;* This routine takes the 32-bit dividend stored in INTACC1:INTACC1+3
;* and divides it by the 16-bit divisor stored in INTACC2:INTACC2+1.
;* The quotient replaces the dividend and the remainder replaces the divisor.
UDVD32    EQU *
DIVIDEND  EQU INTACC1+2
DIVISOR   EQU INTACC2
QUOTIENT  EQU INTACC1
REMAINDER EQU INTACC1
          PSHH        ;save h-reg value
          PSHA        ;save accumulator
          PSHX        ;save x-reg value
          AIS       #-3 ;reserve three bytes of temp storage
          LDA      #!32 ;
          STA      3,SP ;loop counter for number of shifts
          LDA      DIVISOR ;get divisor MSB
          STA      1,SP ;put divisor MSB in working storage
          LDA      DIVISOR+1 ;get divisor LSB
          STA      2,SP ;put divisor LSB in working storage
;* Shift all four bytes of dividend 16 bits to the right and clear
;* both bytes of the temporary remainder location
          MOV      DIVIDEND+1,DIVIDEND+3 ;shift dividend LSB
          MOV      DIVIDEND,DIVIDEND+2 ;shift 2nd byte of dividend
          MOV      DIVIDEND-1,DIVIDEND+1 ;shift 3rd byte of dividend
          MOV      DIVIDEND-2,DIVIDEND ;shift dividend MSB
          CLR      REMAINDER ;zero remainder MSB
          CLR      REMAINDER+1 ;zero remainder LSB
;* Shift each byte of dividend and remainder one bit to the left
SHFTLP    LDA      REMAINDER ;get remainder MSB
          ROLA                ;shift remainder MSB into carry
          ROL      DIVIDEND+3 ;shift dividend LSB
          ROL      DIVIDEND+2 ;shift 2nd byte of dividend
          ROL      DIVIDEND+1      ;shift 3rd byte of dividend
          ROL      DIVIDEND      ;shift dividend MSB
          ROL      REMAINDER+1 ;shift remainder LSB
          ROL      REMAINDER ;shift remainder MSB
;* Subtract both bytes of the divisor from the remainder
          LDA      REMAINDER+1      ;get remainder LSB
          SUB      2,SP ;          subtract divisor LSB from remainder LSB
          STA      REMAINDER+1 ;     store new remainder LSB
          LDA      REMAINDER ;     get remainder MSB
          SBC      1,SP ;subtract divisor MSB from remainder MSB
          STA      REMAINDER ;store new remainder MSB
          LDA      DIVIDEND+3 ;get low byte of dividend/quotient
          SBC      #0 ;dividend low bit holds subtract carry
          STA      DIVIDEND+3 ;store low byte of dividend/quotient
;* Check dividend/quotient LSB. If clear, set LSB of quotient to indicate
;* successful subraction, else add both bytes of divisor back to remainder
          BRCLR      0,DIVIDEND+3,SETLSB ;check for a carry from subtraction
                                    ;and add divisor to remainder if set
          ADD      2,SP ;add divisor LSB to remainder LSB
          STA      REMAINDER+1 ;store remainder LSB
          ADC      1,SP ;add divisor MSB to remainder MSB
          STA      REMAINDER ;store remainder MSB
          ADC      #0 ;add carry to low bit of dividend
          BRA      DECRMT ;do next shift and subtract
SETLSB    BSET      0,DIVIDEND+3 ;set LSB of quotient to indicate successive subtraction
DECRMT    DBNZ      3,SP,SHFTLP ;decrement loop counter and do next shift
;* Move 32-bit dividend into INTACC1:INTACC1+3 and put 16-bit
;* remainder in INTACC2:INTACC2+1
          STA      1,SP ;temporarily store remainder MSB
          STA      2,SP ;temporarily store remainder LSB
          MOV      DIVIDEND,QUOTIENT ;
          MOV      DIVIDEND+1,QUOTIENT+1 ;shift all four bytes of quotient
          MOV      DIVIDEND+2,QUOTIENT+2 ; 16 bits to the left
          MOV      DIVIDEND+3,QUOTIENT+3 ;
          LDA      1,SP ;get final remainder MSB
          STA      INTACC2 ;store final remainder MSB
          LDA      2,SP ;get final remainder LSB
          STA      INTACC2+1 ;store final remainder LSB
;* Deallocate local storage, restore register values, and return from
;* subroutine
          AIS      #3      ;deallocate temporary storage
          PULX           ;restore x-reg value
          PULA           ;restore accumulator value
          PULH           ;restore h-reg value
          RTS
;******FINE_SUB************************************
I use CW_6.0 and when i try to use MAKE  ;  it show mi this message of warning :
Warning : A13003: Value is truncated to one byte
Conversione_Gradi_HEX_OK.asm line 94
Conversione_Gradi_HEX_OK.asm line 95
Conversione_Gradi_HEX_OK.asm line 96
Conversione_Gradi_HEX_OK.asm line 97
Conversione_Gradi_HEX_OK.asm line 98
Conversione_Gradi_HEX_OK.asm line 99
Conversione_Gradi_HEX_OK.asm line 105
Conversione_Gradi_HEX_OK.asm line 106
Conversione_Gradi_HEX_OK.asm line 107
Conversione_Gradi_HEX_OK.asm line 108
Conversione_Gradi_HEX_OK.asm line 109
Conversione_Gradi_HEX_OK.asm line 110
Conversione_Gradi_HEX_OK.asm line 127
Conversione_Gradi_HEX_OK.asm line 139
Conversione_Gradi_HEX_OK.asm line 149
Conversione_Gradi_HEX_OK.asm line 150
Conversione_Gradi_HEX_OK.asm line 151
Conversione_Gradi_HEX_OK.asm line 152
Who can help mi to understand  the correct way for make the unsigned Divide  .......PLEASE ?
where' s the trouble?
Sorry for my bad English.
