i.MX35 PDK Camera Not Working
mattias2
Has anyone managed to get the camera to work on the i.MX35 PDK? Camera functionality is not included in the demo application and I have had a hard time figuring out how to use it in an application.
I have written an application which uses video4linux according to their web site and according to the test program for the i.MX35 PDK. My application works fine (no error codes, pointers to image buffers not 0) but the image is all black. Every byte is zero (I have tried V4L2_PIX_FMT_RGB565 and V4L2_PIX_FMT_YVU420). OV2640 is loaded as a kernel module.
Any suggestions?
mattias2
Problem solved!
I forgot to set member m.offset in struct v4l2_buffer before calling ioctl VIDIOC_QBUF.
mattias2
Problem solved!
