Target is not running if I remove Debugger
Question asked by Aloysius Jegan E A on Sep 2, 2009
Latest reply on Sep 25, 2009 by Aloysius Jegan E A
I am using custom designed board with MCF52254. I'd downloaded a sample code to blink a LED in that board. As long as the debugger is available, I am getting the output. Once I remove the debugger from the board, application is not working.
Can anyone pls tell me, What might be the problem? Either Software configuration or anything do I need to change in hardware?
Thanks.
-AJ
