SEBASTIEN GAL
Data acquisition from ZStar3
Discussion created by SEBASTIEN GAL on Aug 21, 2009
Latest reply on Sep 4, 2009 by Petr Gargulak
Hi Freescale's developpers,
I bought the developpment board: ZSTAR3 and when I use the GUI and especially demo acquire data software, I don't have enough samples in the .xls file.
For example, in the attached file.
I lost a lot of samples indeed the duration between 2 samples isn't same (1/30=33ms). Is it normal? Else do you know what is the root cause? Data transfert from pod to dongle, GUI....
Thanks in advance for support.
Slegal
test_accelero.txt
Message Edited by t.dowe on 2009-09-04 02:00 PM
