I build the evaluation project with code warrior for this board, but got problem for debug, program not stop even set breakpoint at start of main(). Do I need to do any environment settings before debug?
btw, for this board, what's the settings for flash programmer?
hi yucheng,
which eval project u tried??
what is the size of ur code??
if it is greater than 32K then u hv to target for flash.i.e 1st program the KIT then start debug.
