I'm new to the MC9RS08KA2 MCU and I purchased the DEMO board for it.
I'm have both CW Special Edition ver 5.1 and 6.2.
I'm trying to use the example "Low-Cost Digital Timer" PDF as a way to get started but I try to locate the file ETimerR.mcp file referenced in the document and it doesn't exsist in either version of CW.
Does anyone know where I can find that file?
I've searched the Freescale web site and the CD that came with the DEMO board and I can't find it.
Solved! Go to Solution.
Where did you get the pdf from?
The software for AN3413 can be downloaded from the www.freescale.com website, search for AN3413 or AN3413SW.
Thanks Daniel,
I downloaded the AN3413.PDF from freescale but there wasn't any mention of a AN3413SW file.
In the PDF file it said to go to the Codewarrior ETimerR folder, which I could never find.
I guess I know why now. :smileyhappy:
I even searched the Freescale website and it didn't show any reference to software either.
But thank you very much, I searched and found the AN3413SW file and it works great.
I guess I will assume there is a SW file for the examples and look for it next time.
Rod
