MPC8544 bootloader keep printing debug message over and over
duckycool
Hi everyone,
    I'm working on a bootloader of customized board of MPC8544.
    I use the code base of MPC8544DS (demo board) in the LTIB to porting to my board.
    The major difference of my board is that there is no south bridge.
    And I use different memory DIMM from the demo board.
    Could anyone help to check the debugging message from UART as attached files ?
    It keep printing over and over and just can't stop.
    Anyone met this before ? Could you help to provide your experience how to fix it?
    Thanks.
gleb_itech
Did you brake anything? When it started? :smileywink:
duckycool
Hi gleb.itech,
   No, I don't think I brake anything....
   Why you said so ? Could you tell me your what you think it is...?
   Thank you.
gleb_itech
I've got something like that when I misconfigured memory map. When I set wrong memory ranges for e1 framer (or other device I don't remember, but error in ranges anyway) this thing prints errors over and over again at the boot time (by u-boot or even linux yet?). I remember there were words: MSR, call backtrace, GPR regs and so on.
duckycool
Hey, gleb.itech,
  Sorry for late.
  I fix it by turn off an error external interrupt in somewhere...
  So, you are mostly approached the problem.
  Thank you dude!
