HCS12 SPI
Question asked by Mohamed Othman on Jul 30, 2009
Latest reply on Jul 30, 2009 by Mohamed Othman
I have two devices connected on one SPI Port. The first device is a flash memory that takes either Mode 0 or Mode 3 SPI waveform. The other device is a DAC that takes Mode 1 waveform.
The question is, can I have those two devices on the same SPI port?
The question implies ,of course, that I have to setup the SPI waveform (choose which mode to use) every time I communicate with either device. is that possible to do?or is that a "healthy" thing to do?
The flash memory is accessed every 1 second (minimum).
The DAC is accessed randomly.
Thank you,
Prog_ram.
