jmjimenez
LCDC in M52277EVB
Discussion created by jmjimenez on Jul 30, 2009
Latest reply on Aug 3, 2009 by ian lovatt
I recieve the M52277EVB a few days ago. I can programm the flash, the sdram and execute several examples in the board. The problem I have is the LCDC initialization. I did not find any example code using the LCDC, I try to make it by myself but It does not work... Where can I find an example using LCDC for the M52277? (I´m using Codewarrior v7.1).
Thank you very much in advance.
