Is there any way to use the Visualization Tool, particularily the switches, to generate an interrupt? I am currently trying to generate the IRQ_L interrupt using a switch. I understand the IRQ_L is the 2nd LSB of Port E. While I can modify this value using the switch, no interrupt occurs as far as I can tell. Any help would be greatly appreciated as the documentation on the Visualization Tool does not address interrupts. Thank you.
Andy
Solved! Go to Solution.
Hello
Today you cannot generate an interrupt from the visualization tool.
CrasyCat
Hello
Only component I know allowing you to stimulate (Raise) an interrupt is the stimulation component.
Bad news is that component is available in professional edition only and for HC12, HCS12 AND HCS12X MCUs only.
CrasyCat
Hello
CrasyCat
