I am trying to generate S record (s19) file starts from global address 0x7C0000 (Flash Page_F0) on MC9S12XS256 based target. I am using CodeWarrior 4.7 IDE and PE Micro’s BDM interface to download my flash code.
Please provide the information on ‘what changes I need to do in my linker and other files for generating S19 file starts at 0x7C0000 address.
Thank you
Solved! Go to Solution.
Hello
According to my understanding you are looking for a way to generate a S record file for your whole application, containing ^global addresses instead of logical ones.
Am I right?
If that is what you are looking for the .glo file generated automatically if you have created your project using the project wizard is what you need.
This is a S record file where all records are specified using global addresses.
I hope that helps.
CrasyCat
Hello
Am I right?
I hope that helps.
CrasyCat
