Stefan Bongs
Bitfield in Zeropage / Simulator Problems
Discussion created by Stefan Bongs on Jul 21, 2009
Latest reply on Feb 2, 2010 by Stefan Bongs
Using a small code example from a well known book about HCS08...
I tried it out with CW6.02:
#include <hidef.h> /* for EnableInterrupts macro */
#include "derivative.h" /* include peripheral declarations */
#pragma DATA_SEG __DIRECT_SEG MY_ZEROPAGE
volatile struct {
  unsigned char first   : 1;
  unsigned char second  : 1;
  unsigned char third   : 6;
} near my_bit_field;
void main(void) {
  EnableInterrupts; /* enable interrupts */
  /* include your code here */
  my_bit_field.first   = 0;
  my_bit_field.second  = 0;
  my_bit_field.third   = 0;
  for(;:smileywink: {
    __RESET_WATCHDOG(); /* feeds the dog */
  } /* loop forever */
  /* please make sure that you never leave main */
From the CW startup dialog
I'm using:
Rapid application: None
Startup:ANSI
Memory model: Tiny
Float: None
PC-lint: No.
The behaviour is:
Invoking the Simulator lets the routine stop at
Label "Zero_2:" of the Startup code.
The code stops with the lines:
Error: At location 0060 -
Error: Attempt to write to a read-only location.
My question is:
How can I resolve this problem?
May I use the "linker parameter file"? - and how?
Stefan
