Dennis Essenmacher
Except Vector Name: Address Error
Discussion created by Dennis Essenmacher on Jul 17, 2009
Latest reply on Jul 22, 2009 by Rich Testardi
I have a project using the MCF52259 Eval baord I compile for internal flash when I execute the start up I get a "Exception Vector Name: Address Error" after lea __SP_AFTER_RESET,a7 execution.
asm void _startup(void)
 /* disable interrupts */
    move.w        #0x2700,sr
 /* Pre-init SP, in case memory for stack is not valid it should be setup using
    MEMORY_INIT before __initialize_hardware is called
    /* initialize memory */
    MEMORY_INIT
 /* initialize any hardware specific issues */
    jsr           __initialize_hardware
