I was starting (flashin) a new board with a MC56F8002 on it when I got this message "Could not oppen config file: 568002_flash.cfg". It's appear that there is no config file for the 568002 in the folder M56800E Support\initialisation of CW for DSC56800W v8.2.3.
Do I have to modify the 568006_flash.cfg config file or I can find the 568002_flash.cfg file somewhere?
Bruno
Solved! Go to Solution.
See attached the 568002_flash.cfg file.
Pascal
Thanks for your help. I had no trouble flashing the DSC with that config file.
Bruno
