keypad interfacing example
Question asked by Serdar Ozturk on Jun 11, 2009
Latest reply on Jun 12, 2009 by Serdar Ozturk
Dear all;
I am looking for an example code for interfacing a 96AB2 keypad with a 9S12DP256B MCU.
Currently I am stuck with a nonworking code from an old book.  I've connected pins of the keypad to PORT A and the code goes as follows
DDRA = 0xF8; // set PORTA[0:2] as input and PORTA[3:7] as output
for (;:smileywink: {
  PORTA = 0xBF; // assert row 0
  keypress = PORTA;
  if (keypress != 0xBF) // some key has been pressed
    key = scan_key(keypress);
I've a similar block for every row but I'm not even sure if this is the correct way of doing that and unfortunately I am not getting any results with it.  I would really appreciate if someone could give me some hints or pointers to a working code.
Thanks in advance.
