Ross Myers
MCF51JM , XTAL Oscillator not running
Discussion created by Ross Myers on Jun 11, 2009
Latest reply on Mar 13, 2012 by TomE
Hi All,
I'd been working with a prototype PCB using a MCF51JM, everything was progressing fine, then it just seemed to stop working, BDM cannot connect.
This is what I've found.
There is no oscillation on the XTAL/EXTAL pins (It's has an 8MHz crystal).
Reset line is pulsing every 40uS.
So far I've swapped in a new CPU, swapped 5V regs (it has a reset line) and the crystal, but this thing refuses to work now. Before it just quit it had been working ok and I was exectuing code on the MCU, so I know my circuit design is ok to at least make the thing functional.
So what might stop this CPU from running?
Ross
