I have licensed the CW using Dongle.
Now i wish to work on 2 systems over LAN with same license at a time, is that possible.
my CW has got node lock perpectual licensing.
Please somebody tell me if its possible or not.
Thanks in advance.
Solved! Go to Solution.
You can carry the dongle between the two machines, but you can not be using both at the same time. You can set up a floating license to share between the two networked machines, but again, only one machine at a time will be able to use the tools.
---Tom
---Tom
