I have not designed for CAN bus before.
Can anyone with CAN bus experience please comment...
I want to implement a 'listen only' CAN bus micro board, to pick up
certain known packets of data (vehicle speed info). Not sure of the CAN bus
speed yet. The packet filtering seems straight forward enough (famous last words?)
Is the s08DZ60 the best micro? (must be in the S08 family.)
Is there any sample code for initilising the CPU clock , CAN module ?
I can't find anything on freescale. ( but as many have discovered before,
their web page search doesn't often find many relevant software App notes! )
Added p/n to subject.
Lundin, what about listen only mode, in which MSCAN doesn't acknowledge messages and doesn't disturb the bus in any way. Something like automatic baudrate detection wouldn't be possible if there was no listen only mode. What you said applies to listeners that operate in active mode.
I don't think it's bad that all active nodes acknowledge all messages.
Of course, timer pin cound be used, when available. You are right, auto could be achieved without listen only mode. (yes, I meant trial and error in listen only mode). Regards
