Hi all,
I read .docx file (doun't related to my CW project ) from compact disk & exract disk, then activate CW and lunch compiling my project. Compiling frequently abort with request insert compact to CD-ROM (see attachment). This problem was solved only after reload my PC.
Is this IDE error or Windows XP personal problem?
Difficult to determine the cause of the problem.
I think the installation should be corrupted.
I recommend you to re-install the tool.
To avoid problem you must:
- uninstall it,
- delete the installation folder,
- re-install the tool.
Pascal
