yan hongli
CW for Power Architecture v8.8 - MPC8377
Discussion created by yan hongli on May 17, 2009
Latest reply on Nov 7, 2012 by shubhanginisingh
Hi all,
   When I use usb-tap to connect the MPC8377 board by CodeWarrior IDE(vertion 5.9.0), there is a problem occured.
   The steps I debuged show as follows:
   Open CodeWarrior IDE——file——new——project——EPPC New Project Wizard——Project name:hello  Location:C:\hello——Linker:Freescale PowerPC EABI Linker——Select the processor and borad——processor :PowerPC8377,borad:837x RDB——Language:C——Remote connection:CodeWarrior USB TAP——Make——Debug
   then the error information messagebox occured as follows:CCSProtocolPlugin:failed to correctly configure the jtag chain!
    if clicked  "run",the error information messagebox occured as follows:CCSProtocolPlugin:failed to correctly configure the jtag chain(Cable disconnected)!
    Any help? Thank you very much!
