PIL for MPC5744
PIL for MPC5744
ykarata1
Dear All,
I want to implement PIL for MPC5744 DEV_KIT and I have followed  PART 15: Processor-in-the-Loop (PIL) Validation video of NXP.
I could not operate the PIL system. I am getting MP57xx Config is missing error despite of model has it.
I have shared models at the attachment.
Any help will be appreciated.
mariuslucianand
Hello ykarata1@ford.com.tr‌,
Unfortunately, because we are using a custom tlc file, running PIL requires inserting our config block in all the referenced models as well. This should not affect the simulation running for the referenced models. Once I've added the config block, the PIL ran.
Hope this helps,
Marius
mariuslucianand
Hope this helps,
Marius
ykarata1
Dear mariuslucianandrei‌,
Thanks for your support at PIL sample.
When I increased complexity and size of the model , It seems that I get a communication error. I am using same config and same model parameters. What may be the problem?
How can I solve that?
Thanks.
Inside of model:
PIL_VERIFICATTION:
RESULT:
ykarata1
Thank you very much mariuslucianandrei
I have added config file to the model and it has worked.
Thanks a lot. That was my first PIL experience. :smileygrin:
