I am using lsdk2.04 now. I just downloaded the images and root file system using the command below:
flex-installer -i download -m ls1012ardb
In the root file system rootfs_lsdk2004_ubuntu_main_arm64.tgz, I didn't find network manager and modem manager(nmcli and mmcli)
When I tried to do apt-get install network-manager, I got these errors.
W: Failed to fetch http://us.ports.ubuntu.com/ubuntu-ports/dists/bionic/InRelease Temporary failure resolving 'apac.nics.nxp.com'
W: Failed to fetch http://us.ports.ubuntu.com/ubuntu-ports/dists/bionic-updates/InRelease Temporary failure resolving 'apac.nics.nxp.com'
W: Failed to fetch http://ports.ubuntu.com/ubuntu-ports/dists/bionic-security/InRelease Temporary failure resolving 'apac.nics.nxp.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
In
Is there any way I can integrate nmcli and mmcli to our root file system?
Thank you!!
Solved! Go to Solution.
Sorry, it's a stupid mistake.
I resolved this already.
I forgot to enable internet access. There is no internet access at all.
After enabling internet access,
I did apt-get install network-manager, nmcli and mmcli is installed successully.
NetworManager.service failed to be started. I ran apt-get remove network-manager and reinstalled it.
It works now.
It works now.
