i.MX8 MINI weston
i.MX8 MINI weston
story
I am using the i.MX8MINI EVK board and encountered a memory leak.
I developed a qt5 application, the system is linux+weston+qt5. After running for a period of time, the memory will be exhausted and cannot be released.
cat /proc/meminfo
See that SUnreclaim has reached 1.2G.
Later, I did the following test, closed wetston, and used linuxfb to display. The other environment remained unchanged and there was no memory leak after running for a few days.
Can you help me analyze this problem?
Rita_Wang
Which version of BSP are you using? Frame Buffer is not supported on i.MX 8.
