Request for copy of MPC5748G HSM reference manual?
jbrown45
We have multiple MPC5748G eval boards and are currently debugging software that utilises the HSM, we have an image of the HSM firmware however need to enable the HSM. I understand that the HSM is to be enabled via a DCF record however we don't have a copy of the HSM reference manual which details this. Please can I request a copy of this HSM reference manual?
FYI: we are building with GCC (powerpc-eabivle-gcc) and flashing the boards using the OpenSDA (micro usb) interface using the powerpc-eabivle-gdb server.
Many thanks,
Jamie
petervlna
In order to get security reference manual first is necessary to submit a ticket.
https://community.nxp.com/docs/DOC-329745
Security RM is under controlled release and there is defined procedure in order to get hand on it.
regards,
Peter
