setting repo
setting repo
zhangbaobing
I do it as up following,but always fault,
i wander why.
iris_wen
Please try the following steps:
1. Save the attachment in ~/bin
2. $ chmod a+x ~/bin/repo
3. Add the following line to the ~/.bashrc file
   export PATH=~/bin:$PATH
4.$ source ~/.bashrc
zhangbaobing
Executeing this instruction which is fault
so the back instructon still fault.
iris_wen
Do you really follow the steps I provided?
The first step is to save the attachment in ~/bin. Then the repo is already in your computer. You don't need to download again.
Remember to unzip the attachment...ONLY copy the file repo in ~/bin...
zhangbaobing
first ,what is attachment?
zhangbaobing
where is the attachment?
and can you give me specfications ?
zhangbaobing
joanxie
maybe you can refer to the link as below, get the repo from tsinghua
"https://mirrors.tuna.tsinghua.edu.cn/help/git-rep"
I suggest that you can update to the latest version, some packages in the git.freescale.com are removed, if you build the 3.14.28, maybe you will get the connection error even if you can repo sync successfully, I have built 4.14.52 successfully before, but I don't know if you can get 3.14.28 source package or not
zhangbaobing
joanxie
zhangbaobing
i download L4.1.15 still fault
zhangbaobing
joanxie
as I mentioned before, the source code was removed from git.freescale.com, maybe you can refer to my another document
https://community.nxp.com/docs/DOC-346089
zhangbaobing
still fault
joanxie
do you mind reading my document again? as I mentioned,  you couldn't use git.freescale.com, try to use the new command as my document mentions
zhangbaobing
pastedImage_1.pngstill fault
joanxie
I don't find any error according to the pic you attached
iris_wen
Hi Baobing,
Did you reboot or source the .bashrc file by the following command?
$ source ~/.bashrc
iris_wen
If the instruction in user guide is not detailed enough, please follow this link.
https://blog.csdn.net/xuanwolanxue/article/details/104678027?ops_request_misc=%257B%2522request%255F...
zhangbaobing
hi ,that is still false
iris_wen
Could you please share the log?
